20 years agoregarding reset address in flash
Hi all, i am getting the following error when i build the project Post-processing to create cfi_flash.flash Oct 4, 2005 2:49:37 PM - (SEVERE) elf2flash: Boot copier overlaps data ...
20 years agoHi Mike
Actually i am using NDB with Stratix II device i have set the reset address in flash and exception in sdram 1) prog and rom memory in flash and r/w memory in sdram i have taken simple application only printf to the console. i have programmed both .sof and application into flash using flash progammer when i simply program the flash and press reset config switch it is configurng the fpga and led is glowing .but when i press reset cpu switch nothing is being printed onto the screen then i tried run (with ""Reset the target and execute from reset vector (no download)" in the run menu it is just printing the following on the console "nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)" so i am not understanding the things where they are going wrong. can u please me help me in this . 2) also if put prog/rom/r/w/ all memories in sdram and does the above of programming flash and press switch i am not getting any output on the console thanks and regards prasad also small request can u please explain me the use three options in the Run menu and debugger(elf debugger) sub-menu 1) .download into RAM 2) attach to the existing program (no download) 3)""Reset the target and execute from reset vector (no download)" i read the devloper hand book and nios IDE help regarding still it is not clear for me. thanks in advance prasad
