20 years agoregarding reset address in flash
Hi all, i am getting the following error when i build the project Post-processing to create cfi_flash.flash Oct 4, 2005 2:49:37 PM - (SEVERE) elf2flash: Boot copier overlaps data ...
20 years ago --- Quote Start --- originally posted by prasad_forums+oct 7 2005, 04:26 am--><div class='quotetop'>quote (prasad_forums @ oct 7 2005, 04:26 am)</div>
--- quote start ---
will there be any problem if i set
both reset and exception address in flash
and set the program and rom memories also
in flash and only r/w memory in sdram?[/b]
--- quote end ---
that will work fine. slower, but fine.
<!--quotebegin-prasad_forums@Oct 7 2005, 04:26 AM then it that case should i program flash
using flash programmer? --- Quote End --- That's a different topic... and I have to agree with smcnutt, you should look that up in the manual. There's no short answer. Pay special attention to the part about porting your custom board to the flash programmer (which may be in a separate tech note; look in your documents folder or on Altera's site).
