20 years agoregarding reset address in flash
Hi all, i am getting the following error when i build the project Post-processing to create cfi_flash.flash Oct 4, 2005 2:49:37 PM - (SEVERE) elf2flash: Boot copier overlaps data ...
20 years agoHi Mike
will there be any problem if i set both reset and exception address in flash and set the program and rom memories also in flash and only r/w memory in sdram? It should work no? then it that case should i program flash using flash programmer? thanks and regards prasad
