12 years agoregarding data transfer between two custom components or peripherals
I created register as the custom component and instantiated it twice.In a sopc system,now i have 2 separate registers,nios-ii processor,on-chip memory and also one DMA controller.I want to know,how t...
12 years ago --- Quote Start --- You can see sopc generates two different base address for two different register.Using base address you can differentiate and communicate with two registers.For write operation you can use function.IOWR(BASE_ADDRESS,OFFSET,VALUE) and for read operation you can use function IORD(BASE_ADDRESS,OFFSET) --- Quote End --- actually i really want to make data from one component gets transferred to another sir
