20 years agoReducing syslib size
I use Nios II and Quartus 5.0. When I build my application using "small" syslib. The library takes about 15 kB. Is there a way to make my own custom library that would contain only startup code and w...
20 years agoDo I need to initialize jtag uart if one is present in the system? I noticed that I could reduce footprint by writing my own alt_main which does not initialize any device drivers. I have jtag uart and epcs controller, but the bootloader that I am writing is not going to use them. It turned out that if I don't initialize jtag uart I can't get my code to work!
Does this have something to do with time-limited version that I am testing with or a feature that will remain even when I get a license?
