20 years agoRedirect the connection to the local website
Hi everyone,
I am using NIOS 1c12 evaluation kit , NIOS IDE 5.0 , Microtronix Linux Extensions Version 1.4 After I "ifconfig" the target in uClinux , I can access the local website via a web browser. By default , when I browse the site , the target will take me to "/home/httpd" to read files (*.html , *.bmp , *.jpg , ...) there. What should I do to change the default path (ie /var) instead of "/home/httpd" ??? Regards, Quan1 Reply
<div class='quotetop'>QUOTE </div> --- Quote Start --- What should I do to change the default path (ie /var) instead of "/home/httpd" ???[/b] --- Quote End --- Take a look at the /etc/config/boa.conf file at the line "#DocumentRoot /var/www" Warm Regards
