16 years agoRecommended Soft Reset
Hiya In order to perform a soft reset, is it merely necessary to perform the following instructions, or does more need to be done? Is anything likely to be overlooked?
alt_irq_...
16 years agoAlternatively you can create a component that exposes the resetrequest that's part of the Avalon specification that is software writeable. This is similar to DSL's idea only doesn't require any external wiring. Wiring externally is preferable though if you want tighter control over reset since the resetrequest signal just gets logically OR'ed with the reset_n signal.
