16 years agoRecommended Soft Reset
Hiya In order to perform a soft reset, is it merely necessary to perform the following instructions, or does more need to be done? Is anything likely to be overlooked?
alt_irq_...
16 years agoIf ALTREMOTE_UPDATE is included in your design you can use it to issue a hard reset.
Regarding dsl's comment, it may be easier to get to the reset line to use the megawizard and set up a watchdog. Then enable the watchdog to reset the hardware. In any case I don't recommend doing a software only reset. Bill
