20 years agoReceiving bad data from FIFO with DMA transfer
Hi to everyone, i have some problems with the FIFO and reading DMA transactions. After the transaction, and i dumped the data on the screen. At the very beginning i find some data (2 or w...
20 years agoHello Henning, hello Bert.
First of all i like to thank you for your ideas. <div class='quotetop'>QUOTE </div> --- Quote Start --- >If you have cache on Data, there are precautions to take to ensure the consistency of the external memory<[/b] --- Quote End --- i'm using a Nios/f core. To check if it's a cache issue i downgraded the core and removed the cache. the error remains. <div class='quotetop'>QUOTE </div> --- Quote Start --- In SOPC, check that your avalon switch fabric is properly connected to your DMA port.[/b] --- Quote End --- I will go after the connections (again and again :-)). ________ Meanwhile i verified that Memory is OK: I made a testpattern, which i copy from onchip ram to SDRAM and back, and from SDRAM to SDRAM. Hopefully someone else has hint or better a solution. Are there some known issues about configurations, which should be avoided. I will check everything step by step... Thanks Helmar
