16 years ago"readyfordata" won't work
Hi Guys, I'm trying to build an MM Slave component with dataflow control and got some problem. It is very important, that if the target is not ready to receive data then NIOS must stop writing ...
16 years agoThank you for the answer. I do understand that Altera won't support flow control on MM interface, but here still be questions I do not understand:
1. If "readyfordata" was working before and now does not work anymore, but they let the developers to choose in the component editor, that makes not too much sense. It looks like a hanging-out-not-used wire from the box, what is ugly. 2. If they kept the option because of backward compatibility, that is a wrong solution, because the developer will get no any error message if re-compiles a (complicated) old design, but he will not understand why it does not work. An error message saves very long wasting time. 3. Perhaps I'm greenhorn, but don't know yet how can I use ST for a data connection when the inside target / source is user memory, what will be manipulated by C code. 4. If I want to use DMA, that needs MM interfaces, not ST ones.
