16 years ago"readyfordata" won't work
Hi Guys, I'm trying to build an MM Slave component with dataflow control and got some problem. It is very important, that if the target is not ready to receive data then NIOS must stop writing ...
16 years agoYup, what rbugalho is stating is the case. I think the old Avalon DMA does support flow control, so if you think you need it, try that. Otherwise, go with Avalon-ST.
Cheers, - slacker
