16 years agoRead/Write CFI flash
I am using a Cyclone III starte board for some initial design. I am using the CFI flash for configuration and code storage, but I'd like to use unused space for non-volatile storage. I have tried t...
13 years agohi, i have a code to compression of image(bmp to jpg),this code have a out put file(.jpg). My problem is where i can write this file ?(because filesystem with write support, which isn't available in the standard Nios distribution). can i write this file in flash memory?( if yes how)?
thanks in advance. I need your help pleaz.
