16 years agoRead/Write CFI flash
I am using a Cyclone III starte board for some initial design. I am using the CFI flash for configuration and code storage, but I'd like to use unused space for non-volatile storage. I have tried t...
16 years agoWell, my reset vector is in flash, and my exception vector is in ddr... I was under the impression that when setup in such a way, the NIOS system copies the code from flash to ram on bootup and would therefore not need to access the flash anymore.
I am probably wrong, as most assumptions are at least partially flawed. Anyway, it is nice to know that my code does work. I just wish things were a bit more cut and dry with the NIOS... I've spent a lot of time reading and writing code, looking thru the documentation, etc, and there are so many subtle nuances that still get me.
