21 years agoReading the first sector of a CF card
I'm trying to read the first sector of a compact flash card. This is the boot sector and bpb of a fat filesystem. This sector has a lot of information about how the filesystem is(number of sectors, bytes per sector, sector per cluster, etc). The problem is that i cant read it. I can read the second sector. I'm using the compact flash component from this forum and the source code with modifications. This is the code for the test application:
/* This testapplication shall read the bpb*/
# include "system.h"# include "ideutils.h"# include <stdio.h>
int main(void)
char *egenstr = "0 0 0";
if (IDE_initialize()) {//We can do some after this
readCHS(egenstr); //trying to read first sector..
else
printf("Cannot initialize IDE device.\r");
IDE_deinitialize();
printf("\rgoodbye\r\r4");
return 0;
} And this is the output: wrote and verified 10 values successfully.
Identify Device:
serial number: 001705A0603R4656
firmware revision: Vdg 1.23
model number: SanDisk SDCFB-32
LBA mode supported
PIO mode supported: 4
device parameters:
# logical cylinders: 490
# logical heads: 4
# logical sectors/track: 32
LBA capacity = 62720 sectors
successfully wrote default parameters to IDE drive.
readCHS: cylinder: 0; head; 0; sector: 0
CHS = (0, 0, 0); numSectors: 1
timeout awaiting DRQ=1
error register: 0x10
timeout awaiting DRQ in readSectorsCHS()
DRQ not set in status reg in readSectorsCHS()
readCHS() failed.
goodbye I've tried to increase the awaitDRQ time, but it's no use. Is it possible that this card isn't formatted properly? (It's not the one that came with the Nios Development kit.) Thanks for any help. -Ole Kristian Tørresen2 Replies
I think I solved it. There is no sector number 0. I was confused by the second sector, it didn't contain what I expected. This is what the second sector contained:
And it didn't look like the boot sector and bpb. Please correct me if I'm wrong. -Ole Kristian Tørresen0000: FA 33 C0 8E D0 BC 00 7C 8B F4 50 07 50 1F FB FC .3.....|..P.P... 0010: BF 00 06 B9 00 01 F2 A5 EA 1D 06 00 00 BE BE 07 ................ 0020: B3 04 80 3C 80 74 0E 80 3C 00 75 1C 83 C6 10 FE ...<.t..<.u..... 0030: CB 75 EF CD 18 8B 14 8B 4C 02 8B EE 83 C6 10 FE .u......L....... 0040: CB 74 1A 80 3C 00 74 F4 BE 8B 06 AC 3C 00 74 0B .t..<.t.....<.t. 0050: 56 BB 07 00 B4 0E CD 10 5E EB F0 EB FE BF 05 00 V.......^....... 0060: BB 00 7C B8 01 02 57 CD 13 5F 73 0C 33 C0 CD 13 ..|...W.._s.3... 0070: 4F 75 ED BE A3 06 EB D3 BE C2 06 BF FE 7D 81 3D Ou...........}.= 0080: 55 AA 75 C7 8B F5 EA 00 7C 00 00 49 6E 76 61 6C U.u.....|..Inval 0090: 69 64 20 70 61 72 74 69 74 69 6F 6E 20 74 61 62 id partition tab 00A0: 6C 65 00 45 72 72 6F 72 20 6C 6F 61 64 69 6E 67 le.Error loading 00B0: 20 6F 70 65 72 61 74 69 6E 67 20 73 79 73 74 65 operating syste 00C0: 6D 00 4D 69 73 73 69 6E 67 20 6F 70 65 72 61 74 m.Missing operat 00D0: 69 6E 67 20 73 79 73 74 65 6D 00 00 00 00 00 00 ing system...... 00E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 ................ 01C0: 01 00 04 03 60 E8 20 00 00 00 60 F4 00 00 00 00 ....`. ...`..... 01D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 AA ..............U. - Altera_Forum
Hi
You are right. This is not the boot sector. From my experience, if you are using a FAT filesystem, you won't find the bpb at the actual first sectors. There are partition tables and other stuff before that. What I did was to read the first sectors until I found something that confirmed that this is the bpb, meaning the jumpBoot (starts with EB or E9) and also the last two bytes of the sector are 0x55 and 0xAA. I foudn the bpb at logical sector 32. Nir
