read/ write with IORD_32DIRECT and IOWD_32DIRECT problem
Hi Sho,
Thanks for your reply and I am using the Nios V and below is the Nios V and the corresponding Avalon_ext_bus_32x64k module with the port information in the previous post.
Paul
Hi Sho,
I try to make the thing simple. The connection my own module avalon_timeout2 to the Nios V CPU in the platform design as show in the pic (PD.png)
For the avalon_timeout2 is used to access the memory in below VHDL code (sorry that please ignore the name of the module "timeout", as I just quickly modify it)
Then, in the Ashling IDE, I just try to write and read the memory. However, the output are also abnormal by this simple try.
IOWR_32DIRECT(AVALON_TIMEOUT2_0_BASE,0x0,0x00000001); //write address 0 with data 1
uint rddata = IORD_32DIRECT(AVALON_TIMEOUT2_0_BASE,0x0); //read address 0
IOWR_32DIRECT(AVALON_TIMEOUT2_0_BASE,0x4,0x00000004); //write address 0x04 with data 0x04
rddata = IORD_32DIRECT(AVALON_TIMEOUT2_0_BASE,0x4); //read address 0x04
when I run the 1st IOWR_32DIRECT(AVALON_TIMEOUT2_0_BASE,0x0,0x00000001), it seem the read pulse is triggered, address is changing.... (waveform.png)
when I run others 3 code. There are no trigger in the signal tap analyser. It make me confuse....
Do you have any idea on this ?
Paul
The VHDL code for avalong_timeout2
