read/ write with IORD_32DIRECT and IOWD_32DIRECT problem
Hi Paul,
Just to confirm, are you using Nios V?
Could you go into more details, for example PD system?
Sho
Hi Sho,
Thanks for your reply and I am using the Nios V and below is the Nios V and the corresponding Avalon_ext_bus_32x64k module with the port information in the previous post.
Paul
- Paul832 years ago
Hi Sho,
I try to make the thing simple. The connection my own module avalon_timeout2 to the Nios V CPU in the platform design as show in the pic (PD.png)
For the avalon_timeout2 is used to access the memory in below VHDL code (sorry that please ignore the name of the module "timeout", as I just quickly modify it)Then, in the Ashling IDE, I just try to write and read the memory. However, the output are also abnormal by this simple try.
IOWR_32DIRECT(AVALON_TIMEOUT2_0_BASE,0x0,0x00000001); //write address 0 with data 1
uint rddata = IORD_32DIRECT(AVALON_TIMEOUT2_0_BASE,0x0); //read address 0IOWR_32DIRECT(AVALON_TIMEOUT2_0_BASE,0x4,0x00000004); //write address 0x04 with data 0x04
rddata = IORD_32DIRECT(AVALON_TIMEOUT2_0_BASE,0x4); //read address 0x04when I run the 1st IOWR_32DIRECT(AVALON_TIMEOUT2_0_BASE,0x0,0x00000001), it seem the read pulse is triggered, address is changing.... (waveform.png)
when I run others 3 code. There are no trigger in the signal tap analyser. It make me confuse....Do you have any idea on this ?
Paul
The VHDL code for avalong_timeout2
avalon_timeout2 :Library IEEE;use IEEE.std_logic_1164.all;use IEEE.numeric_std.all;entity AVALON_TIMEOUT2 isport(-- Clock/Reset interfaceclk : in std_logic;reset : in std_logic; -- an active high reset signal-- IO interface for read / write accesswrite : in std_logic;read : in std_logic;address : in std_logic_vector (15 downto 0); -- with 2 addresswritedata : in std_logic_vector(31 downto 0);readdata : out std_logic_vector(31 downto 0));end AVALON_TIMEOUT2;architecture RTL of AVALON_TIMEOUT2 istype memory_array is array (0 to 65535) of std_logic_vector (31 downto 0);signal memory : memory_array := (others => (others =>'0'));signal read_data : std_logic_vector(31 downto 0);beginCONTROL : process(reset, clk)beginif reset = '1' thenread_data <= (others => '0'); -- reset read_dataelsif Rising_Edge(clk) thenif write = '1' thenmemory(to_integer(unsigned(address))) <= writedata;end if;if read = '1' thenread_data <= memory(to_integer(unsigned(address)));end if;end if;readdata <= read_data;end process CONTROL;
