9 years agoRead wait on nios component not working / bus timing problem ?
I have made a Nios/qsys VHDL component. The component has a read wait of 2 cycles (defined in signals & interfaces in qsys). (See attached JPG) In the component I implemented for test purposes a shift register and I read the contents of the shift register back with a C program: if (avalon_slave_byteenable='1') and (avalon_slave_address="0010") and (avalon_slave_read='1') and (RcvRdreq="0000") then
RcvRdreq <="1111"; -- fill shift register at read
end if;
if (RcvRdreq/="0000") then -- shift shift register if not zero and set value on avalon bus:
RcvRdreq <='0' & RcvRdreq(3 downto 1); -- shift register
avalon_slave_readdata<="0000" & RcvRdreq; -- put value on bus
end if;
reading value of bus with C program: while (1)
int status;
status =IORD_8DIRECT(COMP _BASE,2);
printf("Status = %x\n",status);
The result I get in the nios console window is 0x0F. If I force the value of rcvRdrReq in the VHDL program, the output changes to the appropriate value, so reading of thebus at the right location works properly. The fact that i get 0x0F means that the value is read directly after issuing the read request and not after 2 cycles? I assume oversaw something but I do not see what ? Please comment. Thanks, Johi.1 Reply
Solved,
Value of 0xFF is correct. Interpretation of timing diagram was the problem. Best Regards, Johi.
