21 years agoread or write date through flash
hello the below sentences is in flash_AM29LV065d.c . volatile unsigned char *fb = (unsigned char *) flash_base; fb[0x555] = 0xAA; // 1st cycle addr = XXX, data = AA i...
21 years agoThe altera_avalon_cfi_flash component should work with any CFI compliant flash which supports programming algorithm 1, 2 or 3. You should check the datasheet for your device to see whether it supports CFI.
Unfortunately a small percentage of older flash devices claim to be CFI compliant but actually aren't. Most of the new ones are OK. But I would expect this flash to work correctly because its from the same family as the 29LV065 which is on the development board.
