21 years agoread or write date through flash
hello the below sentences is in flash_AM29LV065d.c . volatile unsigned char *fb = (unsigned char *) flash_base; fb[0x555] = 0xAA; // 1st cycle addr = XXX, data = AA i...
21 years agoTo BadOman & wombat:
I think that transfering data to\from the flash can use some routine to carry out .For example in niosI the routing amd29Lv065.c can do this . But in the routing there are not the above problems. fb=ext_flash_base; fb[0x55]=0xAA; the above two sentenses can realize flash writing easily. the cache problem still exists ?
