21 years agoread or write date through flash
hello the below sentences is in flash_AM29LV065d.c . volatile unsigned char *fb = (unsigned char *) flash_base; fb[0x555] = 0xAA; // 1st cycle addr = XXX, data = AA i...
21 years agoYes, in 99% of cases using IORD and IOWR will be more obvious and just as fast.
The only case where it might be a good idea to use the bit31 method is where you are passing a pointer to another function (such as memcpy) which wouldn't otherwise understand that it is copying from uncacheable memory. But note that you must never use the bit31 method for accesses to native bus aligned registers, as this might not work in future.
