21 years agoread or write date through flash
hello the below sentences is in flash_AM29LV065d.c . volatile unsigned char *fb = (unsigned char *) flash_base; fb[0x555] = 0xAA; // 1st cycle addr = XXX, data = AA i...
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- I don't use the date cache and instruction cache.[/b] --- Quote End --- If you mean by this that you are using a processor without a data cache then yes, you are correct. If you mean that you are using a processow with a data cache but want to bypass it then you will need to set bit31 or use the IOWR_NATIVE macro instead.
