12 years agoRead data through USB blaster
I have this custom board that has no JTAG connector (set up for Active Serial with an EPCS4 flash). I can load a NIOS2 on it using tricks learned in this forum and I can flash LEDs on board. Is there...
12 years ago --- Quote Start --- ok, I should have been more clear. I do have a 10pin connector on the board, but the JTAG lines to the FPGA (TCK, TMS, etc) are grounded. I program in active serial mode. But then I have no way of sending data back and forth. Hence my thought to repurpose the blaster as a generic SPI IO. Seems like is doable based on what you said, so I guess there is some reading in my future. --- Quote End --- The problem you will have is that the Active Serial signals on the 10-pin header are connected to the EPCS configuration EEPROM. You will not be able to "re-purpose" chip-select, since it is already in use by the EPCS device. If you have other FPGA pins connected to a 100-mil header, then I would recommend using those pins. You can still use the USB-Blaster, but you will avoid possible conflicts with the AS interface. Cheers, Dave
