21 years ago
read data from flash?
Hello:
Now my flash can't use the IDE to program.I think a method that if I can use another software to
program the .bin file to flash,then I write a avalon_interface to communicate between flash and nioscpu.
if this is ok,I will use the below code to read data from flash.
code :
unsigned char *data;
k=(unsigned char*) flash_base;//read data from flash
//k=(unsigned cahr *) ram-base;//read data from ram
for (i=0;i<=100;i++)
data=k ;
But now I have a problem :
if I can&#39;t write command word to flash ,I can read data from flash ?
It means that I can directly read data from flash as read data from ram.because above code can directly read data from ram.
Thank you!
