20 years agoRead BMPfiles in CF and output it
Hello.
I want to make a small system with nios2 development kit(Stratix2 EP2S60ES). All that I want to do is, *Read BMP file in CF (FAT16 format). *Output the BMP file data to custom logic block in Quaruts2 design. *The custom logic output the data to PROT2 connector. I read the forum, and I found several ways (uCLinux, eCos, Altera Host Based File System, Making own filesystem etc). But I can't judge which is the easiest way. Which is the easiest way to make this? And could you explain the detail of the easiest way ? (For me, it is the first time to use nios2. I'm harware engineer. I don't know about software design, well. So, I want to know every step to make it.) Thank you. Best regards.1 Reply
I'd go with uClinux on this. Download uClinux and work through the tutorial. Then modify the "full-featured" demo design for your board to hook up the CF slot (disconnect the LCD). Then it's just a matter of writing a Linux program to read from CF and write to your peripheral.
