When should we use hard external memory interface in the DDR3 SDRAM controller?
Hi
Your understanding is correct. Using the hard memory controller has the advantage in FPGA resource usage because it is hardend block.
When you create the IP via Megawizard GUI you will be asked whether to create the example design or not. if you click yes example design will be generated automatically.
Thank you for your response @yoichiK_intel . Whenever I am enabling "Enable Hard External Memory Interface" in the DDR3 SDRAM Controller with UniPHY in the platform designer, I am getting a series of errors as shown in the screenshot. I feel that the default settings are going for a toss once I have enabled the option. I am looking for a reference design from Intel that has used this hard external memory interface so that I can get a better idea.
