Issue after upgrading my Nios V SoC project from 23.1std to 24.1std
- 1 year ago
This issue was fixed.
There is no issue when all files (SOPCINFO, SOF, BSP, ELF) were generated by the same Quartus Prime version, 23.1std or 24.1std.
Use cases:
--> Using Nios V Command Shell 23.1std
- NO-issue: all files were generated with the same 23.1 or 24.1 version.
- FAIL: SOF files generated with 23.1 and SOPCINFO+BSP+ELF files generated with 24.1std.
- FAIL: SOF files generated with 24.1 and SOPCINFO+BSP+ELF files generated with 23.1std.--> Using Nios V Command Shell 24.1std
- NO-issue: all files were generated with the same 24.1std or 23.1 version.
- FAIL: SOF files generated with 23.1 and SOPCINFO+BSP+ELF files generated with 24.1std.I have run both Quartus Prime Standard versions 23.1 and 24.1 on the same computer using Windows 10. The DE0-Nano board is connected to the computer via a USB interface.
Domingo.
Hello Domingo
The problem seems to be that for some reason jtag is getting disconnected from the board.
We are trying to replicate the issue. We have a question: when you were testing the 24.1 sof file with the 24.1 Nios V Command shell, the BSP and ELF that you used were the ones generated with 23.1 or you regenerated them with 24.1?
Rolando
Use cases:
Domingo.
