SimoneBo
5 years agoHello,
I'm having the same issue with 4.14 kernel.
I'm using an IP block on FPGA registered on interrupt n°73 and a Userspace driver as interface.
If I type "cat /proc/interrupts" it returns
73: xxx 0 gpio-dwapb 3 Edge "my_uio_driver "
with xxx different from 0, but blocked.
I also try to make an IP which rise an interrupt (on 73) periodically but the number of interrupt is still blocked to initial value different from 0.
Have you find a solution?
Thanks in advance,
Simone
