prashant_gohel
1 year agoFailed to launch NIOSV Command Shell. Getting (0xc0000142) application error.
Hello, I'm having trouble with the Nios V Command Shell; specifically, I cannot start the shell (niosv-shell.exe) or the RiscFree IDE. Sometimes the program starts, and sometimes it does not. Opera...
prashant_gohel
1 year agoHi Divya,
Is there any update from the tools team?
DivyaG_Altera
1 year agoHi Prashant,
I'll follow up internally once more to get an update. But in the meantime, here's what they've shared :
For the NIOS V tools to function correctly, quartus_py.exe must be operational. We have not seen any issues with this executable in our regressions. The team suggests checking for any PYTHON* environment variables. To do this, run set in a cmd.exe shell to display all environment variables. If you find any PYTHON* entries, try removing them to see if that resolves the issue. You can remove a variable by running: "set name_of_variable="
Let me if this helps.
Divya
