prashant_gohel
1 year agoFailed to launch NIOSV Command Shell. Getting (0xc0000142) application error.
Hello, I'm having trouble with the Nios V Command Shell; specifically, I cannot start the shell (niosv-shell.exe) or the RiscFree IDE. Sometimes the program starts, and sometimes it does not. Opera...
prashant_gohel
1 year agoHi Divya,
Thank you for your response.
I have updated the SOPC_KIT_NIOS2 path as suggested, but unfortunately, the issue persists—I am still encountering the application error.
My Windows system operates under administrative restrictions. Could there be any background services or registry settings that require additional permissions to run the application properly?
I have also attempted to run the application using "Run as Administrator," but the error remains the same.
DivyaG_Altera
1 year agoHi Prashant,
Is WSL installed on this Windows machine? If so, please try running the same process in WSL and let me know if that avoids the error you’re seeing on Windows.
Divya
