Cyclone 10 GX Nios V Ethernet Ping Issue - UC/TCP-IP Error 20012 and TSE/mSGDMA Debugging ;
- 1 month ago
Hello JL,
Thank you for the explanation and helping in the debugging process.
I am happy to inform you that I have now successfully resolved the issue and can ping the Cyclone 10 GX board with Nios 5 processor successfully.
After further debugging, I found that the issue was not related to the OS_MAX_EVENTS size or event pool depth. The actual issue was related to the network configuration and the initialization sequence of the DHCP server. After correcting the network configuration and ensuring proper initialization, the ping functionality started working successfully.
Thank you again for your time, support, and helpful suggestions
Best regards, Chandan H M
Thank you for the detailed debug notes. The MDIO/PHY ID reads and the OSSemCreate failure inside NetSock_Init() are especially useful.
Root cause of error 20012
NET_SOCK_ERR_INIT_CONN_REQ_FAULT (20012) occurs when socket-layer initialization cannot create the connection-request semaphore(s). In uC/OS-II, OSSemCreate() returns NULL when the free event list is empty. Semaphores, mutexes, mailboxes, and message queues all consume entries from the same OS_EVENT pool, which is sized by OS_MAX_EVENTS.
The failure of the 8th OSSemCreate(0u) inside NetSock_Init() typically means earlier initialization (RTOS, Net_*_Init, drivers, and application tasks) has already used most of the 60 events, so there are not enough left for the socket layer. This does not indicate a problem with the recommended Micrium source files.
OS_LOWEST_PRIO = 80 only affects the task priority range. It does not size the event pool.
Recommended fix
In os_cfg.h, increase OS_MAX_EVENTS. Try 120 or 160 first. Some full Micrium plus application setups need more.
Rebuild and confirm NetSock_Init(&err) returns success (err == NET_SOCK_ERR_NONE).
Optionally measure peak usage by logging remaining free events before and after each major initialization step, then set OS_MAX_EVENTS with some headroom.
Also confirm that other Micrium/OS limits still match your net_cfg.h settings (socket count, connection count, buffers). The immediate blocker matches event-pool exhaustion.
About Ethernet / ping
Your MDIO success (PCS plus Marvell PHY ID 0x0141 / 0x0CC2) and TSE CSR access are good signs that PHY and MAC access are working. Until the stack finishes initialization, ping will not work regardless of DMA health. Please fix OS_MAX_EVENTS first, then validate the packet path.
After stack initialization succeeds - independent TX/RX checks before full TCP/IP
1. Link: confirm SGMII / PHY link-up, and that TSE COMMAND_CONFIG has TX/RX enabled with the correct MAC address.
2. TX-only: build one TX descriptor pointing at a known Ethernet frame in memory, submit it via TX mSGDMA and the prefetcher, check DMA status/completion with no error bits, and capture the frame on the wire.
3. RX-only: arm RX descriptors to free buffers, send a unicast or broadcast frame to the board MAC from the PC, and confirm descriptor ownership flips and the buffer contents match.
Only then reconnect the Micrium interface / TSE + mSGDMA driver and retest ping to 10.0.0.2.
If you can share your os_cfg.h values (OS_MAX_EVENTS, OS_MAX_TASKS, mutex/queue enables) and your net_cfg.h socket/connection counts after the OS_MAX_EVENTS change, we can help size the remaining Micrium resources and review the mSGDMA descriptor layout next.
JL
