Michael2021
1 year agoCan the .jic file, which is an FPGA configuration file, include the on-chip memory file of nios ii ?
Hello If I specify the contents (.hex) of the on-chip memory of my Nios II embedded processor design, compile it through Quartus Prime Pro, and use convert programming to create a .jic file, will ...
FvM
1 year agoHi,
Nios .hex image must be compiled into memory initialization, then it becomes part of configuration bit stream and is loaded with .jic or JTAG configuration.
Michael2021
1 year agoHi
Thank you
