Build Error on Ashling RiscFree 2025.1
I have the same problem but I do not see a solution in the tutorial on Macnica web site. Could you please explicit how to solve the build errors?
I developped the hardware system with Quartus Prime Lite Edition 24.1 and RiscFree v25.1.1. Generating the app and bsp projects from niosV-shell command has worked normally. No problem either for importing projects into RiscFree.
For clarity, I am adding a screenshot showing the result of a build. Surprisingly an hello.elf file is generated in a app/build/default directory (but nothing in app/build/debug).
I also tried to debug the project. An error arises (please see 2nd screenshot) indicating that the debug probe is not avalaible for debug session. The debug probe is USB-Blaster that I used to download the sof file and it is working normally.
Thank you very much in advance for your help.
Thierry
