19 years agoRandom reboot while tcp-ip file transmission
Hello , In my application, I have to transmit a file threw tcp-ip between another embedded linux and my uClinux. Quite offently, uClinux reboots automatically. When I do it again, it doesn&...
19 years agoHello everybody !
Well, I think I found the roots of my problem. It was due to the stack size of a multithread application. The stack size that you indicates at compile time is the stack size of the main thread. You have to indicate the stack size of the other threads. Well, it's good too know ! Bye
