19 years agoRandom reboot while tcp-ip file transmission
Hello , In my application, I have to transmit a file threw tcp-ip between another embedded linux and my uClinux. Quite offently, uClinux reboots automatically. When I do it again, it doesn&...
19 years ago --- Quote Start --- originally posted by helmchen@Feb 26 2007, 07:47 PM <div class='quotetop'>quote
--- quote end ---
--- quote start ---
- maybe you can check your code with a source code checker? is it possible that you fool around with some memory ptr? --- Quote End --- Well it's always possible. I used this application under windows XP thousands of times but there may be errors in the linux specific library. <div class='quotetop'>QUOTE </div> --- Quote Start --- - does uClinux also reboot when your application is not running?[/b] --- Quote End --- No, nether. But, sometimes, the first run of the application is ok. I run the application again and I have the message "BINFMT_FLAT : reloc outside program 0xdf850000 (0x0x5d1ac/0x40140), killing my_app. SIGSEV In other cases, when the tcp/ip connection is established, my telnet is automatically closed and the terminal doesn't answer anymore. [/b] --- Quote End ---
