19 years agoRandom reboot while tcp-ip file transmission
Hello , In my application, I have to transmit a file threw tcp-ip between another embedded linux and my uClinux. Quite offently, uClinux reboots automatically. When I do it again, it doesn&...
19 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- -> Has somebody already have such a problem ?[/b] --- Quote End --- No, actually not. I'm doing a lot of network stuff. Linux is rock stable. <div class='quotetop'>QUOTE </div> --- Quote Start --- What could I do to investigate or solve my problem[/b] --- Quote End --- - maybe you can check your code with a source code checker? Is it possible that you fool around with some memory ptr? - check your design or your memory. - does uClinux also reboot when your application is not running? <div class='quotetop'>QUOTE </div> --- Quote Start --- Is the memory reinitialized after a reboot ?[/b] --- Quote End --- i don't know.
