17 years agoRAM error?
Hello champs, I am running two applications. And each one of them calls the other. It all seems fine until on the 13th loop or so it does this. I'm sorry if the code post is too long, but I gue...
17 years agoHello again,
I have news, I think the problem is in the speed in which the serial port is being read, this makes the buffer full and leaves no RAM space for the other processes? I don't know , it is a hunch :P I did notice that input data is faster than the speed in which it is being stored. So I guess it could be a problem, but don't know if the error is causing the upper output. Still haven't found a solution to the problem. Regards, Francisco
