13 years agoRAM and FLASH shared bus don't worked
Hello everyone, I developped my own custom board which have MT48LC16M16 (Micron SDRam), S29AL032D (Spansion Flash) and Cyclone III EP3C25. RAM and FLASH share data and address bus. The Flash me...
13 years agoHi,
I change the hardware configuration like you said: Nios Cpu <-->Tristate Bridge<-->CFI. the flash and sdram share a common bus 16 bit data and address |-> SDRam Controller I use the nios-command-shell, the results are in the attached file. Please see it! When I used this configuration working with on-chip memory ram, the program work fine. Then I change booting to SDRam, it can't run. I think that Flash can't boot to RAM or something wrong in declaration. Is there problem when i shared 16 bit common data? I'm looking foward to hear you soon! Thanks very much!
