13 years agoRAM and FLASH shared bus don't worked
Hello everyone, I developped my own custom board which have MT48LC16M16 (Micron SDRam), S29AL032D (Spansion Flash) and Cyclone III EP3C25. RAM and FLASH share data and address bus. The Flash me...
13 years agoHi mmTsuchi,
Thanks for your reply, my flash and ram shared address and data bus (my flash is 16 bit mode); i configure flash timing is 40-160-40, byte enable to 3.3V via 4k7 resistor, i checked data and address in shared signals of tristate bridge. the address 0x00000000 that you saw is control by pipeline bridge, so i have that address and the pipeline bridges have different address. I programmed flash with flash programmer, i wonder that there is different booting method from 8 bit flash and 16 bit flash. Do you have any suggestions? Thanks in advance
