11 years agoquestions about sdram and flash
1.in nios system,is there any problem if i install code in sdram and use sdram as data storage device at the same time? in my project, after build the software, it shows: Info: (test2.elf) 61 KB...
11 years agoi think you may not be right.
the flash should stroage both hardware and software, maybe the software size is code + initialized data, but what size of the hardware configure data ?
