20 years agoQuestions about programming the NIOS CPU
I'm not sure if this should be in this forum, or in the general forum, but I'll put it here, since most of my questions are software related. Some background on my project: This is be...
20 years agoAre you sure that I can download the new versions from Altera? I saw that I can download the web editions of both pieces of software, but I didn't see the full versions anywhere. I was using Quartus II 5.1 Web Edition, along with NIOS II Version 5.0 (from a disk), but then I discovered that the web edition doesn't support my particular FPGA, so I had to switch to using the older versions of the software.
