11 years ago
questions about nios interrupts
hi everyone.
there are 2 interrupts in my project
interrupt A has lower poriority than interrupt B
i think if the interrupt B comes when the code is executing the interrupt A's handler, the code should go to the interrupt B's handler.the code return to the interrupt A's handler after finish the interrupt B's handler.
but in my project, in debug mode, i set a breakpoint at the begining of interrupt A's handler, i resume the code (F8), then i let interrupt A happen, so the code stop at the break point, then i let interrupt B happen, i press F5, let the code run single step, the code did not go to interrupt B's handler, and i find the code go to interrupt B's handler untill finish the interrupt A's handler.
why this happed?
# include "alt_types.h"# include "altera_avalon_pio_regs.h"# include "sys/alt_irq.h"# include "system.h"# include <stdio.h># include <unistd.h>
alt_u8 find_zero_counter=0;
alt_32 zero_position[255]={0};
void ft245_interrupt() //lower poriority interrupt
alt_u32 i=0;
alt_u16 j=0;
alt_u16 a=0;
i=alt_irq_enabled();//
j=IORD_16DIRECT(FT245_IRQ_1_0_BASE,0x0); //
a=(j|0x4000);
IOWR_16DIRECT(FT245_IRQ_1_0_BASE,0,0xc000); //clear interrupt
for(;;)
if ((j&0xc000)==0) break;
IOWR_16DIRECT(FT245_IRQ_1_0_BASE,0,0x8000); //tell ft245_driver to read from ft245
void encoder_find_zero() //higher poriority interrupt
alt_u32 i=0;
alt_32 xifen=0,forward=0,backward=0;
IOWR_32DIRECT(INC_CALC_0_BASE,0,0xc0000000); // clear interrupt
while(1)
i=IORD_32DIRECT(INC_CALC_0_BASE,0);//
if ((i&0xf0000000)==0x0) break; //
IOWR_32DIRECT(INC_CALC_0_BASE,0,0x60000000); // prepare S_inc_xifen_at_zero_reg, S_inc_forward_at_zero_reg,S_inc_backward_at_zero_reg, return S_inc_xifen_at_zero_reg,nios should read after interrupt
while(1)
xifen=IORD_32DIRECT(INC_CALC_0_BASE,0);//
if ((xifen&0xf0000000)==0x0) break; //
if ((i&0xf0000000)==0xf0000000) break;//
int main()
alt_u32 i=0;
alt_u32 error_signal_address=0;
alt_u16 j=0;
alt_u32 moire_sin[256]={0};
alt_u32 moire_cos[256]={0};
alt_32 xifen=0,forward=0,backward=0,position=-5;
alt_u16 a=0;
//register interrupt handler of lower poriority interrupt
alt_ic_isr_register (FT245_IRQ_1_0_IRQ_INTERRUPT_CONTROLLER_ID,
FT245_IRQ_1_0_IRQ,
ft245_interrupt,
NULL,
NULL);
//register interrupt handler of higher poriority interrupt
alt_ic_isr_register (INC_CALC_0_IRQ_INTERRUPT_CONTROLLER_ID,
INC_CALC_0_IRQ,
encoder_find_zero,
NULL,
NULL);
//enable interrupt
j=alt_ic_irq_enable(FT245_IRQ_1_0_IRQ_INTERRUPT_CONTROLLER_ID,FT245_IRQ_1_0_IRQ);//
j=alt_ic_irq_enable(INC_CALC_0_IRQ_INTERRUPT_CONTROLLER_ID,INC_CALC_0_IRQ);//
while (1)
return 0;
    i find the
    alt_irq_interruptible();
    alt_irq_non_interruptible();
    can be used to make nested interrupts
    but during debug, i find that only if the higher poriority interrupt happpens before alt_irq_interruptible(), then the code goto higher poriority interrupt handler.
    but if the higher poriority interrupt happpens after alt_irq_interruptible(), then the code still in the lower poriority interrupt handler .
    can the nios interrupt system works like the MCU?
    The internal interrupt controller of Nios does not allow interrupt preemption. You will need to upgrade to external interrupt controller and add the Altera Vectored Interrupt Controller (VIC), which is a Nios peripheral that allow better interrupt handling including interrupt masking.
    Refer to section 32: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_embedded_ip.pdf
    With the VIC, you can set interrupt B to be non-maskable so that it can take over the lower priority interrupt (interrupt A). Which means that interrupt B ISR can be entered even when interrupt A is being serviced.
