14 years agoQuestion on Git Branches to use [nios2mmu vs unstable-nios2mmu]
Hi everyone
I'm currenlty looking into using Linux on the NIOS for my company. Will be getting a DE4 from Terassic shortly but in the meantime I'm doing all the prepwork to understand as much as possible beforehand. I'm a complete newbie to this whole NIOS/Linux dev so please bear with me... I'll be using MMU support. I have been trying the build with MMU support using the following git branches: "unstable-nios2mmu" in linux-2.6 "trunk" in uClinux-dist after setting Vendor=>Altera, Product=>nios2 and then defaulting config settings, building the project has always failed. I have followed the alterawiki instructions as I understand them. Today after reading the info carefully on this page [alterawiki.com/wiki/Downloading_Linux_Distribution ], specifically the last paragraph, I realised that perphaps the "nios2mmu" branch should be checked out instead of "unstable-nios2mmu" as the shell segment on that page suggests. I then managed to complete a succesful build by again just using default config settings. The last paragraph on the index nios/linux webpage [alterawiki.com/wiki/Linux_for_the_Nios_II_Processor] however suggests that the "unstable-nios2mmu" is the branch be used (to get a current build). I appreciate that the "unstable-nios2mmu" branch is at kernel rev 2.6.39 and "nios2mmu" branch at 2.6.35. So, my questions are: 1: Should I be concerned about the "unstable-nios2mmu" branch not compiling 2: Assuming I can get "unstable-nios2mmu" to compile, which branch is the correct/better one to use Cheers Tones
