15 years agoQuestion on Git Branches to use [nios2mmu vs unstable-nios2mmu]
Hi everyone I'm currenlty looking into using Linux on the NIOS for my company. Will be getting a DE4 from Terassic shortly but in the meantime I'm doing all the prepwork to understand as much a...
15 years agoHi Pierre, did get it to download in the end, but it does not boot successfully, during the bootup process I get
BUG: failure at /home/antonie.christie/nios2-linux/linux-2.6/arch/nios2/kernel/time.c:128/nios2_late_time_init()! Kernel panic - not syncing: BUG! I am running on custom hardware with a CPU based on the golden reference for the cycloneIII devkit. I've got a bit of debugging to do and I suspect my hardware or CPU design to be the main cause. Good luck with the rest of the development...
