17 years agoQuestion on custom peripheral extern to SOPC Builder system
Hello, I have a system based on the Nios II processor, and I would like to add an external custom peripheral which disposes of an Avalon Clock, an Avalon-MM Slave Interface and and an Avalon I...
17 years agoHi Jake,
I think the idea I had correspond to the# 2, which consists in create a internal component that just export the avalon bus (what you did in the example you given) , and separately I have my peripheral and I can it to the system in quartus. Else, I don't understand the# 1. If you create a component with the editor and add an Avalon MM slave interface, , that does not create any pin on the system symbol. For the# 3, I tried it, but the SOPC Builder give me the following error when I add my component to the system : "Error: TestComponent: Setting top_level_hdl_module is not allowed when instantiate_in_system_module = false"
