20 years agoQuestion concerning built procedure.
Hello. I have acquired "eCos for Nios II 5.1" already. But, I do not have NIOS2 IDE. Therefore it cannot experiment me. (It became error when the installing "eCos for Nios II 5.1".) ...
20 years agoHello rugbybloke.
Thank you. <div class='quotetop'>QUOTE </div> --- Quote Start --- You don't need the Nios II IDE, but you do need the Nios toolkit, without it you can proceed no further.[/b] --- Quote End --- It tries doing the installation of the Nios toolkit. <div class='quotetop'>QUOTE </div> --- Quote Start --- 1 and 2 I'm afraid I don't understand your question[/b] --- Quote End --- I'm sorry. It's not question. We would like to verify procedure. <div class='quotetop'>QUOTE </div> --- Quote Start --- The build is done using make, either from the command line, or the IDE, as is explained in the manula.[/b] --- Quote End --- I install the Nios toolkit and "eCos for Nios II 5.1". And It tries challenging. Thanks a lot. --- Quote Start --- originally posted by rugbybloke@Sep 5 2006, 10:12 PM i suggest you read the manual which can be found in the components\ecos\docs directory. however to answer some of your questions:.... --- Quote End ---
