20 years agoQuestion about the Avalon Performance Counter
1. alt_get_cpu_freq() is not defined by "altera_avalon_performance_counter.h", which header file can I use for this function? 2. When I run the program using Nios II instruction set simula...
20 years agoThank you very much, paolo http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
--- Quote Start --- originally posted by paolo.gai+feb 8 2006, 03:16 am--><div class='quotetop'>quote (paolo.gai @ feb 8 2006, 03:16 am)</div>--- quote start ---
<!--quotebegin-ruling@Feb 7 2006, 11:55 PM 1. alt_get_cpu_freq() is not defined by "altera_avalon_performance_counter.h",
which header file can i use for this function? --- Quote End --- are you sure? I have it in the file components/altera_avalon_performance_counter/HAL/inc/altera_avalon_performance_counter.h ... it's the last function declared! --- Quote Start --- originally posted by ruling@Feb 7 2006, 11:55 PM 2. when i run the program using nios ii instruction set simulator, it gave me a
warning : "sopc builder system component performance_counter_0 is not
supported by the simulator. simulation may be incorrect if your software
attempts to access it".
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12614)
--- quote end ---
--- Quote End --- I think the simulator only implements a few basic peripherals... --- Quote Start --- originally posted by ruling@Feb 7 2006, 11:55 PM 2. also i got an error: "error! failed memory access in
component cpu_0 - reading data 0x0 from uninitialized memory (addr =
0x3ff68) error! : simulation failed in component cpu_0 at instruction 3257
(pc=0x21e4 instr=0x24000317)."
--- quote end ---
--- Quote End --- In the simulator, You cannot read from a location that has not been previously written... that's typically a bug in the software (unless you want to read some random values...)... In any case look also at this post: http://forum.niosforum.com/forum/index.php?showtopic=314&hl= (http://forum.niosforum.com/forum/index.php?showtopic=314&hl=) --- Quote Start --- originally posted by ruling@Feb 7 2006, 11:55 PM so, which tool except modelsim can i use to
run the program with performance counter? actually, modelsim is very slow if
running a very large code.
--- quote end ---
--- Quote End --- I think you have to use the real hardware :-( Paolo <div align='right'><{post_snapback}> (index.php?act=findpost&pid=12624)</div> [/b] --- Quote End ---
