19 years agoQuestion about SPI core
Hello everyone: I am trying a SPI core(3 Wire serial, provided by altera) to control SPI DAC, and I configured it as a master mode. The Sclk is setted to 25Mhz. But when I observed the s...
19 years ago --- Quote Start --- originally posted by 0quanquan0+oct 24 2006, 10:36 pm--><div class='quotetop'>quote (0quanquan0 @ oct 24 2006, 10:36 pm)</div>
--- quote start ---
<!--quotebegin-hippo@Oct 25 2006, 10:47 AM spi clock will output only when you write data to spi.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18889)
--- quote end ---
--- Quote End --- Thanks hippo. I have see the clock!:) <div align='right'><{post_snapback}> (index.php?act=findpost&pid=18890)</div> [/b] --- Quote End --- /* * "Hello World" example. * * This example prints 'Hello from Nios II' to the STDOUT stream. It runs on * the Nios II 'standard', 'full_featured', 'fast', and 'low_cost' example * designs. It runs with or without the MicroC/OS-II RTOS and requires a STDOUT * device in your system's hardware. * The memory footprint of this hosted application is ~69 kbytes by default * using the standard reference design. * * For a reduced footprint version of this template, and an explanation of how * to reduce the memory footprint for a given application, see the * "small_hello_world" template. * * * write(0, 18); //configure serial interface for MSB first write(5, 3); //set Devices-Index to program ADC Channels 0 and 1 write(18, 80); //set vref to option 2 and adjustment to all zeros write(14, 10); //set output_mode to level option 0, disable output MUX, enable output and offset binary write(17, 83); //set output_delay to enable and set to delay value of 3 write(FF, 1); //write transfer bit (for configurations that require a manual transfer) write(10, 3); //set offset to 3 (for Channel 1 only) write(5, 2); //set Device-Index to program ADC Channel 1 write(FF, 1); //write transfer bit (for configurations that require a manual transfer) Write(5, 4); //set Devices Index to program ADC Channel 2 write(10, 9); //set offset to 9 (for Channel 2 only) write(FF, 1); //write transfer bit (for configurations that require a manual transfer) */ # include <stdio.h># include <altera_avalon_spi.h> extern int alt_avalon_spi_command(alt_u32 base, alt_u32 slave, alt_u32 write_length, const alt_u8* wdata, alt_u32 read_length, alt_u8* read_data, alt_u32 flags);# include "system.h"# include "io.h" unsigned char *pAD9219= SPI_MASTER_BASE; void WRITE_AD9129(unsigned char RegOff,unsigned char DATA) { unsigned char *rdData; //*(SPI_MASTER_BASE+RegOff) = DATA; alt_avalon_spi_command(SPI_MASTER_BASE,0, 1,&DATA, 1,rdData, 0);//ALT_AVALON_SPI_COMMAND_MERGE);//Flag = ALT_AVALON_SPI_COMMAND_MERGE, if you wish to use that function, else put 0 } int main() { while(1) { printf("Hello from Nios II!\n"); //usleep(1000000); IOWR(LED_BASE,0,0xFF); usleep(1000000); IOWR(LED_BASE,0,0x00); /**(pAD9219+0x19) = 0x00; *(pAD9219+0x1A) = 0x00; *(pAD9219+0x1B) = 0x00; *(pAD9219+0x1C) = 0x00;*/ //*(pAD9219+1) = 0x00; //usleep(1000000); WRITE_AD9129(0x0, 0x18); //configure serial interface for MSB first WRITE_AD9129(0x5, 0x3); //set Devices-Index to program ADC Channels 0 and 1 WRITE_AD9129(0x18, 0x80); //set vref to option 2 and adjustment to all zeros WRITE_AD9129(0x14, 0x10); //set output_mode to level option 0, disable output MUX, enable output and offset binary WRITE_AD9129(0x17, 0x83); //set output_delay to enable and set to delay value of 3 WRITE_AD9129(0xFF, 0x1); //write transfer bit (for configurations that require a manual transfer) WRITE_AD9129(0x10, 0x3); //set offset to 3 (for Channel 1 only) WRITE_AD9129(0x5, 0x2); //set Device-Index to program ADC Channel 1 WRITE_AD9129(0xFF, 0x1); //write transfer bit (for configurations that require a manual transfer) WRITE_AD9129(0x5, 0x4); //set Devices Index to program ADC Channel 2 WRITE_AD9129(0x10, 0x9); //set offset to 9 (for Channel 2 only) WRITE_AD9129(0xFF, 0x1); //write transfer bit (for configurations that require a manual transfer) } return 0; }
