11 years agoQuestion about PIO
I have a nios system which interfaces an ADC through Qsys.I have about 20 no:s of PIO's configured for this. 16 PIOs for the databus from ADC,one for Chip select,one for adc reset,two for SOC of a...
11 years ago --- Quote Start --- I have a nios system which interfaces an ADC through Qsys.I have about 20 no:s of PIO's configured for this. 16 PIOs for the databus from ADC,one for Chip select,one for adc reset,two for SOC of adc.when i create all the pio's its always showing the problem in nios that its not able to download the .elf file.If i reduce the no: of PIO's by 19,then i can download the program to nios.What can be the reason for this? --- Quote End --- Which PIO are you removing? Does the error go away if you remove anyone of the PIO's, or is it just specific to a certain one? If the problem is fixed by removing a PIO from lets say your adc reset, then you can point back to that as your issue. Can you post the error message(s) you are receiving?
