20 years agoquestion about module programming
Hi!
I have a question about developing a module un uClinux. I have a working program under Linux, which I have to "convert" to uClinux. Theoretically, it wouldn't be much problem. The fact is, that in my previous version, I have two modules: crc nvram crc is loaded as a module first. After, nvram is loaded, and nvram uses the crc functions. Other modules also use the crc functions. So... is this possible in uClinux? When I compile my nvram module, it shows a warning:Warning: "crc16" undefined! And when I try to load it, it shows insmod: cannot insert 'NVRAM_driver.ko': Unknown symbol in module (-1): No such file or directory In linux, the nvram driver should find the crc symbols in ksyms, but I'm not sure in uClinux it will be able... Some sugeestions? aLeX1 Reply
Hi!
I've found the way to do it work! I forgot to add:
to the crc file. I don't know why in linux wasn't needed, but in uClinux, ot does. bye aLeXEXPORT_SYMBOL(crc16);
