20 years agoQuestion about flash-programmer
hi!
when i use flashprogrammer download my process to epcs64.it always failure.the info in console window is: # ! /bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.# cd D:/altera/kits/nios2/examples/myprocess/flashprogram/software/memtest_0/Debug # Creating .flash file for the FPGA configuration $SOPC_KIT_NIOS2/bin/sof2flash --flash=U59 --offset=0x00000000 --epcs --input=$SO PC_KIT_NIOS2/examples/myprocess/flashprogram/flashprogram.sof --output=flashprog ram.flash Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert --device=EPCS64 --option=flashp rogram.opt d:/altera/kits/nios2/examples/myprocess/flashprogram/flashprogram.sof flashprogram.pof Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Processing ended: Mon Apr 03 15:56:57 2006 Info: Elapsed time: 00:00:03 Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert flashprogram.pof flashprogram.r pd Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Processing ended: Mon Apr 03 15:57:01 2006 Info: Elapsed time: 00:00:04 WARNING: Default charset GBK not supported, using ISO-8859-1 instead # Programming flash with the FPGA configuration $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=flashprogram.flash --sof=$SOP C_KIT_NIOS2/examples/myprocess/flashprogram/my_program/system/my_program.sof --e pcs Apr 3, 2006 3:57:02 PM - (??) nios2-flash-programmer: Launching Quartus Programm er to download: d:/altera/kits/nios2/examples/myprocess/flashprogram/my_program/system/my_p rogram.sof Error: Can't configure device. Expected JTAG ID code 0x020B40DD for device 1, bu t found JTAG ID code 0x020B30DD. Error: Operation failed Error: Quartus II Programmer was unsuccessful. 2 errors, 0 warnings Apr 3, 2006 3:57:05 PM - (??) nios2-flash-programmer: Unable to download SOF: d: /altera/kits/nios2/examples/myprocess/flashprogram/my_program/system/my_program. sof, exiting WARNING: Default charset GBK not supported, using ISO-8859-1 instead # Creating .flash file for the project $SOPC_KIT_NIOS2/bin/elf2flash --flash=U59 --epcs --base=0x0 --end=0x7fffffff --i nput=memtest_0.elf --output=epcs_controller.flash --boot=$SOPC_KIT_NIOS2/compone nts/altera_nios2/boot_loader_epcs.srec WARNING: Default charset GBK not supported, using ISO-8859-1 instead # Programming flash with the project $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=epcs_controller.flash --sof=_ _NO_SOF_PLEASE__ --epcs Apr 3, 2006 3:57:05 PM - (??) nios2-flash-programmer: SOF-download skipped. Send (32) failed. Unable to synchronize with target. Apr 3, 2006 3:57:25 PM - (??) nios2-flash-programmer: Error opening target hardw are Apr 3, 2006 3:57:25 PM - (??) nios2-flash-programmer: In order to program flash, you must first create a purpose-built flash-programming design (i.e. FPGA configuration) and associate it with your particular board. The Nios development kit is delivered with purpose-bui lt flash-programming designs pre-built for several development boards. If you wi sh to program flash on your own board, you must first create a flash-programming design. The process of creating a flash-programming design for your board is mostly automated. From a bash-shell, execute this script: mk_target_board --help The help-message includes references to other documentation on programming flash and targeting Nios systems to custom board designs. - exiting. WARNING: Default charset GBK not supported, using ISO-8859-1 instead # Creating .flash file for the project $SOPC_KIT_NIOS2/bin/elf2flash --flash=U5 --base=0x00000000 --end=0x7fffff --rese t=0x801800 --input=memtest_0.elf --output=ext_flash.flash --boot=$SOPC_KIT_NIOS2 /components/altera_nios2/boot_loader_cfi.srec WARNING: Default charset GBK not supported, using ISO-8859-1 instead # Programming flash with the project $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=ext_flash.flash --sof=__NO_SO F_PLEASE__ --base=0x00800000 Apr 3, 2006 3:57:25 PM - (??) nios2-flash-programmer: Input file empty--no data to program into flash. Exiting. WARNING: Default charset GBK not supported, using ISO-8859-1 instead /////what's the reason? thankyou!/////1 Reply
hi! i have made some changes but it still can't dwonload to my epcs16.this is the info. thank you very much!!!!!!!
# ! /bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.# cd D:/altera/kits/nios2/examples/myprocess/flashprogram/software/memtest_0/Debug # Creating .flash file for the FPGA configuration $SOPC_KIT_NIOS2/bin/sof2flash --flash=U59 --offset=0x00000000 --epcs --input=$SO PC_KIT_NIOS2/examples/myprocess/flashprogram/flashprogram.sof --output=flashprog ram.flash Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert --device=EPCS64 --option=flashp rogram.opt d:/altera/kits/nios2/examples/myprocess/flashprogram/flashprogram.sof flashprogram.pof Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Processing ended: Tue Apr 04 09:14:51 2006 Info: Elapsed time: 00:00:03 Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert flashprogram.pof flashprogram.r pd Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Processing ended: Tue Apr 04 09:14:55 2006 Info: Elapsed time: 00:00:04 WARNING: Default charset GBK not supported, using ISO-8859-1 instead # Programming flash with the FPGA configuration $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=flashprogram.flash --sof=$SOP C_KIT_NIOS2/examples/myprocess/flashprogram/ceshif/system/ceshif.sof --epcs Apr 4, 2006 9:14:57 AM - (??) nios2-flash-programmer: Launching Quartus Programm er to download: d:/altera/kits/nios2/examples/myprocess/flashprogram/ceshif/system/ceshif.s of Apr 4, 2006 9:15:04 AM - (??) nios2-flash-programmer: Error copying data to the flash target Read failed @00000000 WARNING: Default charset GBK not supported, using ISO-8859-1 instead # Creating .flash file for the project $SOPC_KIT_NIOS2/bin/elf2flash --flash=U59 --epcs --base=0x0 --end=0x7fffffff --i nput=memtest_0.elf --output=epcs_controller.flash --boot=$SOPC_KIT_NIOS2/compone nts/altera_nios2/boot_loader_epcs.srec WARNING: Default charset GBK not supported, using ISO-8859-1 instead # Programming flash with the project $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=epcs_controller.flash --sof=_ _NO_SOF_PLEASE__ --epcs Apr 4, 2006 9:15:05 AM - (??) nios2-flash-programmer: SOF-download skipped. Read failed @00000000 Apr 4, 2006 9:15:10 AM - (??) nios2-flash-programmer: Error copying data to the flash target WARNING: Default charset GBK not supported, using ISO-8859-1 instead # Creating .flash file for the project $SOPC_KIT_NIOS2/bin/elf2flash --flash=U5 --base=0x00000000 --end=0x7fffff --rese t=0x801800 --input=memtest_0.elf --output=ext_flash.flash --boot=$SOPC_KIT_NIOS2 /components/altera_nios2/boot_loader_cfi.srec WARNING: Default charset GBK not supported, using ISO-8859-1 instead # Programming flash with the project $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=ext_flash.flash --sof=__NO_SO F_PLEASE__ --base=0x00800000 Apr 4, 2006 9:15:11 AM - (??) nios2-flash-programmer: Input file empty--no data to program into flash. Exiting. WARNING: Default charset GBK not supported, using ISO-8859-1 instead
